20 Most Recent
Targus (ACB10US) Bluetooth Wireless Adapter Questions & Answers
Need a driver for Windows
Windows 7 does not support this driver
Click Here for support information . Now I found the driver for your need. Go ahead and run the Vista one this should work for you.
Click Here I hope that this assisted you. Thanks for using FixYa! John
Lost Software
You may try this
LINK.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Need driver
Please follow this link.
http://www.targus.com/us/product_details.aspx?sku=acb10us
thanking you
davevipul197
My old computer with built
Your computer had an antenna around the display monitor - this doesn't. Since it uses microwave frequency, it requires line-of-sight to transmit and receive signals between the communicating devices.
Need drivers for a targus
In all of my searching... I finally stumbled across what I believe is a solution!
A Lenovo Bluetooth driver called 7zbv14ww.exe has installed and is working fine with my Targus acb10 (non US). right now, i'm playing games and i have my blackberry hooked up! hope this helps because i searched for three days straight!
Targus Adapter is Freezing my computer!
This adapter is obviously not compatable with Vista as it was originally used in Win98, Win2000 and XP and there are no drivers on this site for Vista.
http://www.targus.com/us/drivers_manuals.asp?SKU=ACB10US
For the price of a new Vista compatible Bluetooth adapter it's not worth re installing another operating system as all adapters should have all the same uses as each other.
My computer is not recognizing the device...
Goto this web address and download and install the driver for either windows XP or Vista depending on what you are running.
Try to download the vista drivers from the link below.
http://www.targus.com/us/Downloads/ACB10_V6_0_1_6300_Vista_only.exe
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
- Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
- Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
- Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
- Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
- Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
