20 Most Recent
LG KP500 Cookie Unlocked Phone with 32 MP Camera (Black) 5 Items bundle kit Cell Phone + Rapid Car Charger + 4GB microSD Card + Black Horizontal Pouch Case + Universal LCD Screen Protector Questions & Answers
PUK CODES LG KP500
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.
Click HERE to navigate.
Kind regards
Lock123
How could i get an unlock code for free for a htc
Honestly there is no free
HTC phone unlock code unless you have good standing account with your network provider and have an excelent reason why you need that unlock code. If you don't have that condition your provider still take some charge for that unlock code. Charge is flexible aproximately $60-$90 depends on model phones. If you want cheaper
HTC unlock code you can try to find at third party sites it can save a lot of your money and of course saving more time.
I just got my phone and tried to set it now it
The phone asks for PUK code ( Personal Unblocking Key) if a wrong PIN code is entered repeatedly
PUK code is related to the SIM card you are using with your phone and not the phone itself.
The code can be supplied only by the cellular service provider. So, kindly call the customer support of your cellular service provider using another phone and they will provide you with the code free of charge after verifying the details.
Please note: Entering a wrong PUK code ten times in a row permanently disables the SIM card. So please be careful while entering the PUK code.
Hope you will find this information helpful. Thanks for using FixYa.
I need a puk code for lg kp500 and a pin code
puk code comes with the service provider. It is different for each sim card. All you have to do is to ask the service provider for the puk code and they will provide it.
Pin code also comes with a phone number. That too is given at the time you buy the phone. And if it is incorrectly entered the phone asks for a puk code. So the pin code can also be obtained from asking the service provider.
Good Luck
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
