20 Most Recent
Toshiba 23HLV85 Television Questions & Answers
I have the toshiba 23hlv85
Hello Corey hi, Its not the power source but the power supply circuit board on your TV. this is where the red light is connected. this simply means that there is an overload/short circuit somewhere inside your TV. this overload prevents the power supply board to turn on for protection. To find the overload in your TV, needs the services of a technician. Usually they swap boards and isolate where the problem is. I suggest you inquire about your problem to your dealer. see if they have after-market service.
After working perfectly for 4 years suddenly the
This is due to the fact that the front end of the RF section is faulty and so there is no signal available to the video amp to be processed.
The fault can be any where from the input tuner, the VI F/SIF sections or the conversions( A/D).
You might ahve to start with a signal test to arrive easily at issue, possible that it can be the tuner itself as it most prone to failure.
Finally check the mode section secction of the AV/tuner which can be a suspected area due to a gate failure.
Main circuit board part # 72796173..cost of
$185 here http://tv-part.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&cid=0&q=72796173&x=0&y=0
and $263.95 here http://www.partstore.com/SearchResults.aspx?q=72796173&x=12&y=7
Toshiba 23HLV85 LCD TV/DVD inverted image
Yes,Ur main Tuner board have problems,the ICS on the board is not coverting.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
TV DOES NOT COME ON AT ALL
Bad power supply.
Symptoms: No display at all, no power indicator light, no sound from speakers, momentary popping or clicking noise, "burnt electronics" smell. Typically caused by failed capacitors. Can be usually be repalced and continue to have working display for a long time.
Repair: Replace power supply. Super cheap when it's just a couple of bad capacitor to medium expense when repalcing whole power supply unit.
-=/ Daft Tech /=-
No video
First before you spend crazy money on a new monitor try updating your video card driver.
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM •
Toshiba...
Answered
on Apr 07, 2024
