20 Most Recent Toshiba 65H82 65" Rear Projection Television Questions & Answers
My toshiba 65 rear projection is blurry and has dual image
The fluid that is used to cool the face of the 3 tubes has become clouded and discolored. This fluid is serviceable. I wouldn't try it myself if you've never done it before. A TV shop can do the job.
10/11/2014 3:03:31 AM • Toshiba 65H82... • Answered on Oct 11, 2014
Toshiba projection tv no picture
You will need convergence work to this unit. Not cheap.(Not recommended for DIY unless already experienced in this type work). Might contact a local servicer experienced with Toshiba & see if they can give you a quote over the phone. Be sure you are sitting. This is probably a good time to consider entering the 21st century & look at LCD or LED flat screens.
7/24/2014 8:38:42 PM • Toshiba 65H82... • Answered on Jul 24, 2014
How to fix a hyperboard on a 65 inch toshiba projection tv
Here is the info about repairing a hyperboard How To Fix Toshiba Rear Projection HDTV wavy lines
6/13/2014 5:31:31 PM • Toshiba 65H82... • Answered on Jun 13, 2014
Dosn`t want to trun on
Mos likely aging capacitors on the power control board, they can be replaced if your handy with a soldering iron.
6/5/2014 2:45:34 AM • Toshiba 65H82... • Answered on Jun 05, 2014
Bugs behind screen
You have to disassemble the set to clean out. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help.
4/11/2013 4:41:35 PM • Toshiba 65H82... • Answered on Apr 11, 2013
Star like spots all over screen
Do we have the correct model number as listed here? This set should not be able to have this problem-----If model is different than listed here advise me.Only thing here MIGHT be excessive dust or such on the lens of the 3 tubes the model listed has.
5/21/2012 2:31:49 PM • Toshiba 65H82... • Answered on May 21, 2012
Need to replace bulb
Remove and examine the lamp this set (based on model indicated here) uses---is it intact or shattered inside?Easy to get at and instructions are in the owner manual.
4/19/2012 1:59:47 PM • Toshiba 65H82... • Answered on Apr 19, 2012
Problem with picture
Bad convergence ic's. STK 392-120, best replacement. Or check for bad solder connections in convergence circuit.
11/28/2011 7:00:37 AM • Toshiba 65H82... • Answered on Nov 28, 2011
From looking at the pictures
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
8/11/2011 10:03:30 PM • Toshiba 65H82... • Answered on Aug 11, 2011
No picture no sound
One of the most common problem with current TV's is heat. Since they tend to get hot, one of the things that goes out a ton is the fuse or power supply. Depending on the TV and the Manufacturer this can be an easy fix, sometimes you don't even have to solder if it's the power board. I bet if your TV does nothing that's the case. Check around online by your make/model and you'll get a pretty good idea of how easy it is to fix.I found a Parts purchase list online, but you'd have to know the part number for the ones that are broken.http://www.searspartsdirect.com/partsdirect/part-model/Toshiba-Parts/Television-Parts/Model-65H82/1100/0333200/50021150/00001Good luck! Hope this helps and don't forget to rate.Gtaplytmpt
7/22/2011 9:56:36 PM • Toshiba 65H82... • Answered on Jul 22, 2011
Hi - I have a
What is the problem?
5/20/2011 4:36:48 AM • Toshiba 65H82... • Answered on May 20, 2011
Toshiba 65H82 65" Rear Projection Television Logo
72 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
hear sound but all
  • Televison & Video
