20 Most Recent
Philips LCA3123 Projector Lamp for Bsure SV2, Cclear SV Questions & Answers
Lamp light flashing
hi during my investigating i found that the eletrorode surge arrester was causing the problem epcos component 800 083 number i found a device from a projection tv and it worked i also checked epcos web site but could not the accurute device number . they will ask u to use a ruler to measure the device size of the component thanks
I just bought two new
I find that often this is resolved after has been on for a few minutes as the tube warms up.
Particularly true in current cold spell !!
Pete
Transmission difficulty with my Philips Fax machine (PPI 27 1B/05).
I don't know much about faxes but I have used a couple and found nearly all such problems are caused by the recipient machine encountering a problem and closing the transmission line.
Standard machines aren't so bad and most problems I have encountered are caused when a desktop computer is used instead of a fax machine - they are often switched off except during office hours for instance...
I recently purchased a Phillips
You don't. All those units have different frequencies and are designed to work within their original system. If you add a another handset, chances are it will not communicate with the base unit.
