20 Most Recent
JVC KW-XC777 CD / Cassette Player Questions & Answers
How do I set the clock?
I found this on Page 22 of the JVC KW-XC777 Manual
http://resources.jvc.com/Resources/00/00/97/49688ien.pdf
1. Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display. (See
page 23.)
2. If “CLOCK HOUR” does not appear
press >>| or |<<
repeatedly
until it appears.
3. Adjust the hour.
4. Press >>| or |<< until “CLOCK
MIN (minute)” appears on the display.
5. Adjust the minute.
6. Finish the setting.
To check the current clock time while the unit
is turned off, press DISP (display).
The power turns on, the clock time is shown for 5
seconds, then the power turns off.
I hope that helps.
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r
Memory (+12v Constant)
Yellow
Ignition (+12v Switched)
Red
Ground (-)
Black
Dimmer
Pink/White (Alpine only)
Power Antenna
Blue
Amplifier Turn-on
Blue/White
Phone Mute
Light Blue (Sony only)
S p e a k e r s
Right Front (+)
Gray
Right Front (-)
Gray/Black
Left Front (+)
White
Left Front (-)
White/Black
Right Rear (+)
Violet
Right Rear (-)
Violet/Black
Left Rear (+)
Green
Left Rear (-)
Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Cant set the dam clock
Off the top of my head as I can't find manual on JVC site. I think it's an old model? Anyway, frm memory, press andhols the select button until clock display flashes. Then use thefrward and back buttons to select hoyrs and minutes. When selected use up and down button to advance or ****** the time! Pres forward or back again to select the othjer(hour or minute).
I hope my memorie serves me right.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
CLOCK SETTING
1. Press and hold "Select" for more than 2 seconds.
2. Press < or > until clock hour is displayed.
3. Press - or + to adjust hour.
4. Press < or > until clock min. is displayed.
5. Press - or + to adjust minute.
6. Press "select" one more time and now you're set!
Here is a link to the JVC head unit's manual:
http://books.jvcservice.com/Download/931358667/49687IEN.pdf
