20 Most Recent
Fire Magic A790i Questions & Answers
Not hot enough
Check that the gas jet is not partially blocked limiting the amount of gas out. To up size my bbq to a hotter flame I used oxy welding set tip drills and gently opened up a size. worked a treat and cooked quicker. maybe you can get next size jets for your problem. check that the regulator is not restricting the gas flow.
My igniter does not light
The potential problem is you're either out of gas or the regulator is locked up.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's
Hose/Regulator Assembly. It runs about $30.00 at any home center or
hardware store that sells grills & accessories. If you replace it,
turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
I have a fire Magic
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
