Errors in your registry are one of the common causes for incorrect file associations on your windows system. It is highly recommended that you
check your registry for file association errors (will also check for any other registry errors).
The ETL file type is primarily associated with 'Eclipse' by The Eclipse Foundation. Eclipse is an open source community whose projects are focused on building an open development platform comprised of extensible frameworks, tools and runtimes for building, deploying and managing software across the lifecycle. Your workspace setup may consist of several projects from one or more repositories. Once you have setup your workspace, you can share it with others by exporting a Team Project Set.
Cannot access ETL files on windows?
When windows gives you an error message saying that it
"Cannot open ETL files", this means either:
A. You need to identify a program that can open the file
B. Or your registry may be damaged
RECOMMENDED:In both cases it is strongly recommended that you
run a free scan for registry errors.
File extension: .ETL
Detailed information for file extension ETL:
Primary association: Eclipse
Company: The Eclipse Foundation
Other applications associated with file type ETL:
- ThermaData Logger (Log Data File) by Electronic Temperature Instruments LtdThermaData Logger is a cost effective, self-contained temperature data-logger or blind recording thermometer designed to record the temperature of the surrounding environment. This association is classified as Database.
- Windows2000 Trace Log(TRACEDMP.EXE from Win2000 Resource Kit to create DUMPFILE.CSV for viewing by other applications) (performance monitoring)
