20 Most Recent
Ice-O-Matic Ice O Matic ICE0250HA Cube Ice Machine Questions & Answers
I Have ice-O-Matic How to fix the ice machine if it only drops ice one and sometimes it'll drop Ice when you turn it back on and then off again.
If your Ice-O-Matic ice machine is only dropping ice intermittently or inconsistently, there are a few potential causes and troubleshooting steps you can try:
- Check the water supply: Ensure that the water supply to the ice machine is sufficient and that the water inlet valve is fully open. Inspect the water line for any kinks or blockages that could restrict water flow.
- Clean the condenser: A dirty condenser can affect the ice machine's performance. Clean the condenser coils using a soft brush or vacuum cleaner to remove any dust or debris that may have accumulated.
- Check the water filter: If your ice machine is equipped with a water filter, check if it needs to be replaced or cleaned. A clogged or dirty water filter can hinder water flow and impact ice production.
- Inspect the harvest cycle: The ice machine's harvest cycle may be experiencing issues. Ensure that the harvest switch is functioning properly and that the control board is working correctly. Refer to the manufacturer's manual for instructions on troubleshooting the harvest cycle.
- Verify the ice thickness control: If the ice thickness control is not properly set, it may prevent ice from dropping consistently. Adjust the ice thickness control according to the manufacturer's instructions to ensure the correct ice thickness for dropping.
- Check for sensor issues: Ice machines often have sensors that monitor ice levels, temperature, or other parameters. Make sure these sensors are clean and functioning correctly. If a sensor is malfunctioning, it may need to be replaced.
Ice grid is loose
those wires are held in by screws you will have to pull the slack from one end to the other surpintine
4/7/2014 1:53:28 PM •
Kitchen...
Answered
on Apr 07, 2014
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
