20 Most Recent
ViewSonic PJ501 Multimedia Projector Questions & Answers
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
My blues are green
reset the settings to factory default and check the lamp for bulges, black spots, fogging or flaking, and replace as necessary. if not better, you may have a fried polarizer on one of the lcd panels due to excessive dust and heat. that will need to be replaced, buy you may have to replace the entire optical engine, as many manufacturers don't sell the individual parts.
Picture has a yellow tint. It's from an old video
Hello there:
The best way to describe this is what is called screen burn in.
this is very common on screns that have games or pictures that arre displayed for long periods of time without being shut down just like on a computer screen when a screen saver is not used .
there is nothing wrong with the bulb.
the yellow that you are seeing is actually burned into the glass part of the projector and the lense
so if you can and feel like you can dissasemble the projector dissassemble it and locate the glass and see if you can get the yellow tint that will be on the glass and the lense off by using some rubbing alcohol and a cottomn swab
But if it wont come off you will have to replace the lense and the glass ok
Hope this is very helpful for you
Best regards Michael
Viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
