20 Most Recent Imperial IFS50OP Deep Fryer Questions & Answers
When converting to lp I changed the orifices and reg is that all I need?
Change pilot orfice as well
4/16/2012 11:25:39 PM • Imperial IFS50OP... • Answered on Apr 16, 2012
My Imperial Heavy Duty Commercial Deep Freezer is
Turn it up...
9/14/2011 6:02:53 PM • Imperial IFS50OP... • Answered on Sep 14, 2011
Want to convert to lp
To convert a natural gas fryer to LP, you have to change out the orfices... We can order the kit for you and have it shipped in 1-2 days...Call Ray at Restaurant Equipment Outlet, 888-542-5959, with model and serial number of your fryer... Thanks, Susan REO Cincinnati, Ohio
9/13/2011 4:38:11 PM • Imperial IFS50OP... • Answered on Sep 13, 2011
Tank leaking oil
You didn't say how old is the deep fryer. There are 3 ways to do this job. A. take out the old tank and weld it ( most likely this is a very unreliable because when you start welding a spot, you may find another one somewhere else, and it never ends, and the welding shop will not give you any warranty for their welding too. ) and it is not cheap on labour alone. B. Replace the old tank from Imperial , They give you 90 days warranty on replacement parts. Please check out the labour first. C. This is the best way replace the whole unit with a new one they give you 1 year part & labour warranty. This is cheap compare with trying to repair the old one. You should shop around before you decided what to do. Good luck hope this can help.
9/24/2010 4:41:46 AM • Imperial IFS50OP... • Answered on Sep 24, 2010
2answers
Imperial IFS-40 - 40 lb. Gas Floor Fryer Natural Gas. The orifice stays alight after the burners go off?
The gas valve isn't cutting off fully. Call for service. Only gas certified engineers can work on gas appliances. ..
3/17/2024 4:48:30 AM • Imperial Kitchen... • Answered on Mar 17, 2024
HOW TO CHECK PILOT LIGHT WHEN IT WILL NOT STAY ON . THIS IMPERIAL GAS FRYER
Usually needs the thermocouple replacing. As it is a gas fryer, it has to replace by a gas certified technician. Please don't type in all CAPS, it is considered SHOUTING and more difficult to read.
3/12/2024 3:00:50 AM • Imperial Kitchen... • Answered on Mar 12, 2024
Imperial Deep Fryer pilot won't stay lite
When the pilot goes out and won't stay lit is is usually because the Thermocouple safety device has failed. The burners should never be on when the thermostat is off. That is incredibly dangerous. You need a gas registered service technician.
3/4/2023 1:16:29 AM • Imperial Kitchen... • Answered on Mar 04, 2023
2answers
Imperial ir 6 first 2 burners burn to high
you may have a clog in the low burning ports..or the high one may be to large an opening..worn..
11/16/2018 12:38:52 AM • Imperial Kitchen... • Answered on Nov 16, 2018
2answers
Need parts for gas fryer imperial ifs 40
try ERplacementParts.com
1/6/2018 7:17:35 PM • Imperial Kitchen... • Answered on Jan 06, 2018
2answers
My imperial deep fryer is leaking from somewhere. Is there suppose to be a drip pan?
No, there is no drip pan. If the oil is leaking from the drain spout, you can screw a plug in it. If it is leaking from the tank around the burner tubes.... then you need a new fryer.
11/15/2017 9:09:18 PM • Imperial Kitchen... • Answered on Nov 15, 2017
What is the imperial equivalent to 142cc?
Here is your answer 142 cc 0.12494253303388 qt-uk
3/11/2017 1:49:32 AM • Imperial Kitchen... • Answered on Mar 11, 2017
Imperial IFS50OP Deep Fryer Logo
Popular Tags
5 questions posted
Top Imperial Kitchen Appliances - Others Experts
Paul Carew
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Imperial Kitchen Appliances - Others
Most Popular Question
tank leaking oil
  • Kitchen Appliances - Others
