20 Most Recent
Barska Optics BARSKA 1040X50 AO Varmint Target Dot Rifle Scope Questions & Answers
Adjustment
you have a gun mount problem its not a scope problem ,,,the scope mount is not a good fit to the gun and is off set to the barrel,,,
set the scope to center of its ajustment and then "pack out the scope with a bit of old 35mm film till you get it close to were you need it to hit then do the last bit of ajustment on the turrets,,this works for lift and windage
My elevaition crosshair wont raise high enough to
your crosshair actually needs to go lower to raise the point of impact. if thats what you meant than you have a mounting/scope problem. the scope should naturally align within the adjustment range assuming the mounts are correct and the scope is functioning and mounted properly.
10X40 monocular. Prism is loose and has come out
I ASSUME this device has collimation screws on the side of the barrel-- if it does not then the prism cannot be aligned.
If it does have collimation screws then hold the small monocular up to a lighted window and adjust the screws until you get a ROUND circle of light-- if you see a "catseye" light circle the prism is not collimated.
I want to know if
Telescopes that are advertised as having powers of 300, 500, 600 or whatever are scams. You will not be able to see anything but dim blurs if you attempt to use them at such magnifications.
There is a good website for telescope beginners that explains the issues clearly at
THIS LINK
I just purchased a used
You mean a BRAND new telescope and no manual-- or did you buy it used?
Sorry but no manuals for that small telescope on the internet. However Meade maintains a website with all of their telescopes lokkunder th refractor or reflector HEADER for one similar to your telescope.
http://www.meade.com/manuals/index.html
