20 Most Recent
Gibson GAM155Q1A Air Conditioner Questions & Answers
Central ac system compressor and fan no t running
Most likely the capacitor.Any signs like that is a definite.The outside unit some run a capacitor for motor (compressor) an fan.If you are replacing your self discharge capacitor first or you will get hurt.
It tries to come on but then stops after a few
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
What are the BTUs for a Gibson Room Air Conditioner model # GAS256Q2A1
Contact your local technician and specialist of the company in which you bought this product. Check out their FAQ page and help page then contact them for further information. Follow this link to get started
https://www.manualslib.com/manual/889218/Gibson-Room-Air-Conditioner.html
Gibson furnace blinking 4 times then pauses, flame won't stay on
The four flashes is failure of ignition. It could be the flame sensor dirty. The furnace tries to light four times before you get the four flashes. The board then locks out for one hour unless the power is removed and restored. You could try gently cleaning the flame sensor with fine steel wool. If you don't have fine wool you can use a crisp dollar bill.
with the burner firing the yellow flame sense indicator should be pretty much locked on or flicker briefly. If it just occasionally flashes on then the flame sensor rod needs to be cleaned.
hope this helps you.
Frost on coils on condensers
i will assume you are talking about evaporator --a few reasons restricted air flow coils dirty -air filter clogging --fan not working or operating properly --low on freon ---turn fan on and with a spray bottle mix water and a little liquid soap and spray coils the fan will pull mixture thru coils keep spraying do not wipe the coils you can get injured and also damage coils an replace with new filter if still freezes over will need to check freon level and fan operation
