20 Most Recent
Optoma H56 Multimedia Projector Questions & Answers
Upside down projection
Download the latest display driver for your video card. If you are using ATI vc's then download and install the Catalyst Application which will allow you to rotate the screen orientation .
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Cooling fan problem projector
I have a similar issue though mine isn't quite as extreme as yours. Got a couple things you can do.
1. clean out the projector with compressed air. You might have dust building up on components that is trapping heat.
2. Your fan might be burning out. Needs to be replaced. I'm still working on trying to figure out what tipe of fan it needs.
3. The temperature sensor might be going bad. This one is less likely and most complex to solve as it depends on how the system measures the temp. I haven't checked in detail yet.
4. Replace the whole unit or send it in for repair. Both options will be costly...
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Dramatic increase in fan noise
Hi there
If you place your hand on the machine and you can actually feel the vibration , you might be looking at a faulty Colourwheel.
If not , try cleaning the fans by blowing it out. If the problem still occurs you might have to replace the fans.
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
My projector has a password locked but I forgot the password. If there is any way to turn it on, please help.
Optoma DLP projector
EX631
Reset instructions according to this
https://factory-reset.com/wiki/Optoma_Service_Menu
Optoma Service Menu Instructions
Most of our Optoma Service Menu methods require the use of an original remote, typically you can not do it with just the buttons on the front of the set. If you no longer have your remote or have damaged it, we recommend that you purchase a
Optoma Remote before trying to enter the service menu.
Method 1
- Press simultaneously {UP} & {ENTER} buttons twice.
- Press simultaneously {LEFT} & {ENTER} buttons twice.
- A Service Menu will be displayed
- Then to access the Full Service Menu: Press the {UP}, {LEFT} & {DOWN} buttons once.
- To exit, turn the Projector Off.
Method 2
- Press the {UP} {UP} {LEFT} {LEFT} buttons.
Method 3
- Press the {POWER} {LEFT} {LEFT} {MENU} buttons.
Method 4
- Press simultaneously the {RE-SYNC} {ENTER} {SOURCE} buttons on the Projector.
Method 5
- Press the {POWER} button.
- It will show: "Power Off" or "Picture Mute".
- Then press the {LEFT} button 8 times slowly.
Method 6
- Press {MENU} {6} {1} {9} {MENU} buttons.
- To exit the Service Menu: Press {MENU} {6} {1} {9}
