20 Most Recent
Optoma PK102 Projector Questions & Answers
I need to reset my projector. It is bazook after I
hy , i have an optoma pk 102 projektor and i have a promblem i start the projektor , shows me the "optoma logo" and than it's starts flashing and restarting , and show again the optoma logo. i try to connect to the laptop and show me the extend monitor for 10 secounds and restarting again, how can i fix the problem,maybe i cand upgrade the firmware?.Thanks
How can I reset my
- The way to reset these is to remove the battery and wait 1 hour and then re insert the battery.
- Slide the battery cover off.
- Lift the bottom side of the battery.
- Pull the battery up and out.
- Also you want to make sure any video you attempt to play with this has been properly converted by the Optoma Video Encoder.
Regards,
Tony
I have a Optoma PK102 portable projector and I
Ahoy there. I have the
Aaxa P2 and they told me to convert all the powerpoint slides to jpg first and then use the onboard media player's slideshow feature. It works great. I don't know if the pk102 has the same features but I hope that helps. If not you might want to consider getting a different one.
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
My projector has a password locked but I forgot the password. If there is any way to turn it on, please help.
Optoma DLP projector
EX631
Reset instructions according to this
https://factory-reset.com/wiki/Optoma_Service_Menu
Optoma Service Menu Instructions
Most of our Optoma Service Menu methods require the use of an original remote, typically you can not do it with just the buttons on the front of the set. If you no longer have your remote or have damaged it, we recommend that you purchase a
Optoma Remote before trying to enter the service menu.
Method 1
- Press simultaneously {UP} & {ENTER} buttons twice.
- Press simultaneously {LEFT} & {ENTER} buttons twice.
- A Service Menu will be displayed
- Then to access the Full Service Menu: Press the {UP}, {LEFT} & {DOWN} buttons once.
- To exit, turn the Projector Off.
Method 2
- Press the {UP} {UP} {LEFT} {LEFT} buttons.
Method 3
- Press the {POWER} {LEFT} {LEFT} {MENU} buttons.
Method 4
- Press simultaneously the {RE-SYNC} {ENTER} {SOURCE} buttons on the Projector.
Method 5
- Press the {POWER} button.
- It will show: "Power Off" or "Picture Mute".
- Then press the {LEFT} button 8 times slowly.
Method 6
- Press {MENU} {6} {1} {9} {MENU} buttons.
- To exit the Service Menu: Press {MENU} {6} {1} {9}
