1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
One bad lead or faulty connection point can cause a computer to shutdown continue restarting on a cycle or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
37 questions posted
3,409 Questions
2,234 Questions
1,799 Questions
796 Questions
724 Questions
