20 Most Recent
LG Glance VX7100 Cell Phone Questions & Answers
My Lg Vx7100 has been
For an old phone power cycling is mostly battery related. I would remove the battery, clean the contacts on the handset and replace with a new fully charged battery. It that does not help I would try to back up my contacts and shop for a replacement.
Lg phone will not turn
Turn off the phone, remove the battery. Wait a few seconds, insert the battery again, then turn the phone on.
Can I use my Lg
You can use any Verizon-branded non-prepaid phone on PagePlus. If you used your Glance on prepaid, you may not be able to activate it, but most LG Glance phones should be OK to activate. The phone also must not have been reported lost or stolen.
The easiest way to check this is to call PagePlus and ask them to check if they can activate the phone.
If this helped you, please help me by giving a few thumbs up!
How can I download photos from my LG-VX7100 to my
you can use a datacable to download it to your computer and also intall the reqired driver of your phone in the computer so that your phone will get identifed by the computer when you connect it thats all
Pictures to computer
All you do is sent it throught a text msg. Instread of puttin a phone number in the send column put your setting to abc mode or word mode and send it to your email address. Then wait then check your inbox.
How come my LG Env3 only displays the Verizon logo?
There are a few possible reasons why your LG Env3 is only displaying the Verizon logo:
- The phone is stuck in a boot loop: This can happen if the phone's software becomes corrupt, causing the phone to continuously reboot and display the Verizon logo.
- The phone is stuck in a firmware update: If the phone was in the middle of a firmware update and the update failed, it may be stuck in a loop and only display the Verizon logo.
- The phone has a hardware issue: If the phone's hardware has become damaged or malfunctioning, it may only be able to display the Verizon logo.
- The phone is locked: If the phone is locked with a passcode or pattern and you've tried to enter it multiple times, it may display the Verizon logo.
If you're unable to fix the problem by yourself, the best solution would be to contact the manufacturer or the carrier to get the phone checked.
It is also possible that the phone was previously owned by someone else, it may be locked to a carrier and the only option is to contact the carrier and ask for assistance
May have blocked number how do i unblock
On the android system go to phone and recent and locate the number and select it by touching it for a couple of seconds you should get a menu that comes up and says block/unblock. If the number is not listed or block is the only option then it is not blocked
10/24/2016 10:29:40 AM •
LG VX Cell...
Answered
on Oct 24, 2016
