20 Most Recent
Tannoy Sensys 7 Speaker Questions & Answers
Bose acoustimas speaker output jacks not working
try to trace your problem inside the main circuitry of the jacks ( open it and see on the solder side of the Printed circuit board(where all the electronic components and soldered/welded if there are loose connections (small cracks... use magnifying glass if you have one) then solder them.
also check for the transistor amplifiers and output capacitors....
check also for the connectivity of all wirings!
No sound from subwoofer
have you checked for the continuity of the wirings? check for the resistance of your speaker from it jack..... it should measure close to 8ohms or 4ohms using a digital multimeter (DMM). check also the sub out jack of your reciever if there is a signal from it using your main speakers if they come with jacks also (turn the volume low to prevent damage to other speakers you connect on it!
