20 Most Recent
Mtd Snowthrower 208cc 26" Questions & Answers
WHAT YEAR WAS THIS MTD GOLD MADE...S/N 1C120B30159
Usually, the date of manufacturing and similar information is located on the same sticker. If you can't see/find this or locate your user manual, you should try calling their technical help line so they can search your serial# in their database: 1-800-668-1238
4/9/2024 6:07:33 PM •
Mtd Garden
Answered
on Apr 09, 2024
MTD 618-04907A Transmission stuck in reverse
Here are a few things you can check to troubleshoot why your TroyBilt riding mower is stuck in reverse:
- Check the transmission fluid level. The transmission fluid level should be between the "full" and "add" marks on the dipstick. If the fluid level is low, add the specified type and amount of fluid.
- Check the transmission fluid for leaks. If the transmission fluid is leaking, it could be causing the transmission to slip. Repair any leaks and refill the transmission fluid.
- Inspect the transmission linkage. The transmission linkage is a series of cables and rods that connect the transmission lever to the transmission. If the linkage is damaged or misadjusted, it could be causing the transmission to stick in reverse. Inspect the linkage for damage and make sure it is properly adjusted.
- Inspect the transmission gears. The transmission gears are responsible for transferring power from the engine to the wheels. If the transmission gears are damaged, it could cause the transmission to stick in reverse. Inspect the transmission gears for damage and replace any damaged gears.
If you have checked all of these things and the mower is still stuck in reverse, you may need to take it to a qualified mechanic for further diagnosis and repair.
Here are some additional tips for troubleshooting transmission problems:
- When diagnosing a transmission problem, it is important to check the fluid level and for leaks first. Low fluid levels or leaks can cause the transmission to slip, which can lead to other problems.
- If the fluid level and for leaks are okay, then you can start inspecting the transmission linkage and gears. The linkage should be properly adjusted and the gears should not be damaged.
- If you find that the linkage or gears are damaged, then you will need to replace them. You can also try adjusting the linkage if it is not properly adjusted.
- If you have checked all of the above and the mower is still stuck in reverse, then you may need to take it to a qualified mechanic for further diagnosis and repair.
8/26/2023 9:51:26 PM •
Mtd Garden
Answered
on Aug 26, 2023
Does an MTD model 21AA414A729 use gear oil ?
No, it uses a mineral oil/clay grease.
Owners manual is avaiable for download, no fee.
https://www.mtdparts.com/en_US/prior-year-models/yard-machines-garden-tiller-model-21aa414a729/21AA414A729.html
The transmission is pre-lubricated and sealed at the factory. It requires no checking unless the transmission is disassembled. To fill with grease, lay the right half of the transmission on its side, add 22 ounces of Benalene 920 grease, and assemble the left half to it. This grease can be obtained at your nearest authorized dealer by ordering part number 737-0300.
5/13/2023 11:43:44 PM •
Mtd Garden
Answered
on May 13, 2023
Mtd yard machine forward issue
it sounds like someone has switched the gears of operation in your device. You would need to call 1-800-269-6215 to reach MT yard to send someone out to fix it . Otherwise, you could have a major accident. Thank you.
10/5/2022 7:16:59 PM •
Mtd Garden
Answered
on Oct 05, 2022
B&S 17.5hp model 313707 type 0162-E5 code 020311ZE there's a yellow wire that's not hook up
basic diagnostics do not include parts list.
is there fuel in the tank?
is the fuel getting to the carburater?
pull the plug, is fuel in the cyliner? wet plug?
Does the engine turn over when ignition key is turned?
is there a spark when the engine turns over.
are all controls set correctly? driver in seat safety switch working transmission in neutral, blades disengaged. throttle set to start. parking brake on?
7/10/2022 9:54:07 PM •
Mtd Garden
Answered
on Jul 10, 2022
