20 Most Recent
LG 37LE2R 37 in. LCD TV Questions & Answers
My screen keeps flicking on and off.
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Remote control stopped working 37le 2r
You need to check whether the batteries are running out of power first.
If you replace brand new batteries and still does not work, then you need to replace a brand new remote from your nearby TV dealer.
My lg only shows black
Your color picture tube is no good. you need to replace it. They are expensive, 175.00-200.00
Lg 37le2r will only show black and white picture.
I've encountered that experience before it needs some technical knowledge because the raster for rgb on your lcd is going bad and the video signal out put cable is mis aligned get someone to re align the raster and your video signal output cable
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
