20 Most Recent Chicago Pneumatic 1/2" Air Impact Wrench Questions & Answers
3answers
Air veins for impact wrench
You can follow this link for C.P. parts. Just look up your model, good luck! Search by Parts Breakdown
3/25/2020 2:32:03 PM • Chicago... • Answered on Mar 25, 2020
Worn drive on my CP half-inch impact
That impact is distributed by Harbor Freight, though I doubt it is 25 years old. They may have a rebuild kit there, but a new one just like it is around $35.
This one:
is priced at $24.99
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95310
9/3/2018 6:17:34 AM • Chicago... • Answered on Sep 03, 2018
4answers
My CP 734 has no power under load. Is there a
I used to repair these impacts for a living. Simplest first thing to do is back off the three 1/8" set screws in the back a couple turns. Pour a little varsol into the air inlet and plug it in. run the gun until your hand is black, (wear a glove). Once the varsol stops disconnect the air, add a few drops of air tool oil and tighten the screws slowly and evenly. You will hear the impact rpm increase. If your gun doesn't speed up to it's original scream you will have to remove the four 5/32" set screws and see what's worn. To open it hold the impact by the nose 3" off the table and position a center punch in the hole of the anvil shank with the same hand and hit it with a hammer hard enough to overtake the spring. The guts should drop on to the table in tact. The guts are in twp parts, the hammering mechanism, and the air motor. The three 1/8" screws hold the motor together. You will soon see the problem. Take the back off the air motor and it will show your if the veins are worn. Cjeck the end plates for wear. You can turn the end plates down on a lathe if available. As a rule of thumb, if the anvil shank is dry buy a repair kit, if it's wet, buy a tune-up kit. If the ring on the anvil shank doesn't turn, buy a repair kit and change your sockets. When rebuilding these front seal often leaks. These impacts are supposed to use 30 weight oil, but a mix of Ingersol Rand grease and 30 weight oil, ( just till it's slightly runny) will stay much longer. Assembling the anvil assembly can be tricky until you figure out how to hold the shank and two pins with the same hand. Good luck.
2/13/2016 3:25:37 PM • Chicago... • Answered on Feb 13, 2016
3answers
The 734 cp impact wrench has not been used for a
Put 4 or 5 drops of oil into the air line opening. Connect an air supply and burst the trigger a few times. The settings are 1-less 4 more. It's all up to the application and they are not specific settings.
2/23/2015 3:16:56 PM • Chicago... • Answered on Feb 23, 2015
Looking for a rebuild kit
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC Part Listing Order Page
11/28/2014 10:36:20 AM • Chicago... • Answered on Nov 28, 2014
Need diagram for cp-734
11/28/2014 10:20:36 AM • Chicago... • Answered on Nov 28, 2014
How do you fill the oil for the oil bath clutch on
THERE IS A PLUG ON THE RIGHT SIDE OF THE TOOL JUST BELOW THE FORWARD REVERSE SELECTOR. THE TOOL REQUIRES 3/4 OZ OF SAE 30 NON DETERGENT OIL. FOLLOW THIS LINK TO VIEW THE MANUAL. http://etools.cp.com/cpvscatalogue/files/CA157440.pdf
11/28/2014 9:49:57 AM • Chicago... • Answered on Nov 28, 2014
I have cp 9540b impact wrench. recently i have
ONE COMMON PROBLEM WITH THIS TOOL IS THE CYLINDER HAS TO BE INSTALLED IN A SPECIFIC DIRECTION. THE CYLINDER HAS ONE END THAT IS COMPLETELY ROUND WHICH FACES THE REAR COVER AND THE OTHER END HAS 2 FLAT CUTS WHICH FACE THE FRONT OF THE TOOL, WHEN THE CYLINDER IS INSTALLED BACKWARDS THE TOOL WILL RUN BUT WITH LOW POWER. SPECIAL NOTE WHEN ASSEMBLING THE AIR MOTOR THE 3 SCREWS THAT HOLD THE MOTOR TOGETHER THEY NEED TO BE TIGHTENED EVENLY TO PREVENT BINDING AND DAMAGE TO THE ENDPLATES, AFTER TIGHTENING IT MAY BE NECESSARY TO TAP THE END OF THE ROTOR TO SET THE MOTOR. FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC Part Listing Order Page
11/28/2014 9:40:49 AM • Chicago... • Answered on Nov 28, 2014
Manual for chicago air impact 1/2 or other.
If you have a newer of current tool you can go to CP.COM. If it's an older tool try this link: Chicago Pneumatic Service Repair Parts OEM Pro Am Tools
10/13/2014 1:38:15 AM • Chicago... • Answered on Oct 13, 2014
I just fixed my cp
This is from the CP734H manual. Check clutch oil once each month. Use 3/4 oz. (22ml) of SAE#30 oil or equivalent. Make sure the oil is non-detergent.
10/13/2014 1:34:23 AM • Chicago... • Answered on Oct 13, 2014
Is the oil used for CP734 air wrench for air line use & air gun body oil one & the same product
C.P. recommends 3/4 oz. of SAE30 oil in the hammer (clutch) mechanism, and SAE10 for the air motor.
8/31/2014 4:14:52 AM • Chicago... • Answered on Aug 31, 2014
Exploded gun diagram
you can go to CP.com, ereplacementparts.com, powertoolrepairohio.com. note CP.com will only have parts list for current tools, the other websites will have lists for older tools.
8/26/2014 1:31:44 AM • Chicago... • Answered on Aug 26, 2014
Air opertes but locks up under load
Sounds like you might have a problem with the hammer (clutch) mechanism, these types of impacts are direct drive there a re no gears, so the hammer (clutch) mechanism must have the ability to splip after impacting to allow the air motor to turn. Disassemble and look for broken hammer pins, hammer dogs. If you need a parts list you can go to CP.com, powertoolrepairohio.com or ereplacementparts.com
8/26/2014 12:23:43 AM • Chicago... • Answered on Aug 26, 2014
Where can i buy "block ca141848" for cp air wrench 734
You can try ereplacenmentparts.com Follow this link and they a picture of the parts that you are looking for! Block CA141848 for Craftsman Power Tool eReplacement Parts Hope this helps.
8/25/2014 11:52:48 PM • Chicago... • Answered on Aug 25, 2014
0answers
0answers
Clean and service
Be the first to answer 12/25/2013 3:16:52 AM • Chicago... • Posted on Dec 25, 2013Be the first to answer
How much oil to put in a rebuilt impact?
non detergent 30 weight 1 ounce
6/27/2013 8:31:35 AM • Chicago... • Answered on Jun 27, 2013
My impact wrench quit working and i disasembed it
you can download a parts list form CP.COM or http://oemproamtools.com/CP_Parts.htmit will show you the order that the parts have to go.
4/28/2013 7:43:37 PM • Chicago... • Answered on Apr 28, 2013
Cp7775-6 is not taking load while tightening
If the tool is new I would call the company that you purchased it from and see if they will give you another one or let you send it in to be repaired. When you say its just rotating does it hammer hard or does it sound like its hammering real quick like a chattering? Does the air motor stall out and just blow air? If sending it back is not a option I would unscrew the four allens off the clutch housing and inspect the clutch to see if anything is broken. If all else fails give A-1 Hydraulics a call at 770-907-0013 and we should be able to help you out
11/17/2012 9:45:25 PM • Chicago... • Answered on Nov 17, 2012
CP 734 Trigger Broken
If you are still looking for this part I would call power tool repair at 330-630-0022 and order that part number. From the breakdown it seems you have the correct part number
11/13/2012 2:50:41 AM • Chicago... • Answered on Nov 13, 2012
Chicago Pneumatic  1/2" Air Impact Wrench Logo
Popular Tags
36 questions posted
Top Chicago Pneumatic Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Marty Warge
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Chicago Pneumatic Air Tools & Compressors
Most Popular Question
cp 9540b impact wrench recently
  • Air Tools & Compressors
