20 Most Recent Porcher 40050 Classic Elongated Toilet Bowl Only, White Questions & Answers
I have a Porcher one-piece toilet with a bad
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
1/6/2010 2:20:55 PM • Porcher 40050... • Answered on Jan 06, 2010
Does not flush completely. Works 2 out 3 times.
Needs new flushing mechanism. Remove Cistern, Remove flush siphon and either replace siphon washer or replace complete siphon.
6/10/2009 12:06:41 PM • Porcher 40050... • Answered on Jun 10, 2009
2answers
Where can I find a replacement parts to rebuild a porcher Veneto one piece toilet
http://www.porcher-us.com/assets/documents/porcher/spec/SpecSheet_3362.pdf http://www.guillens.com/POR/9712.htm Parts breakdown. Specs are above. Immediately below is the company site but they may only offer some support rather than directly providing any parts. I list a couple of possible sources for parts after that. Welcome to Porcher http://www.guillens.com/buy/product/97120-00-001/22791 Porcher Faucet Toilet Parts
5/14/2022 9:00:52 PM • Porcher Home • Answered on May 14, 2022
2answers
My Porcher Calla toilet hinge nuts have broken. They are plastic. I cannot find replacements for the nuts. The inside diameter of the nuts is between 3/16 and 1/4.
It may be possible to replace the cheap plastic hardware with real metal hardware. Back in the day, hardware was brass.
11/21/2020 2:10:14 AM • Porcher Home • Answered on Nov 21, 2020
I have a porcher cygnet toilet I need to replace the flushing mechanism, how do I do it
https://www.youtube.com/watch?v=FlJ3UQlkEdU First you will need to obtain the kit or parts necessary for replacement, compare your parts to your existing before doing anything, you will need your model number and if you had a picture more help could be offered. Begin by turning off the water supply to the toilet, keep a small bucket handy to catch the water, disconnect the supply line at the toilet if your are doing a complete replacement. If its only the handle again a handle kit will need to be obtained for your specific model no need to turn off water but keep in mind your exact handle or button placement. When you have the correct parts its just a matter of remove and replace and take photos of before so you can reference what goes where if you get sidetracked.
11/11/2018 7:41:08 PM • Porcher Home • Answered on Nov 11, 2018
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
2/20/2018 9:55:03 AM • Porcher Home • Answered on Feb 20, 2018
0answers
How do i tighten soft close toilet seat on a porcher cygnet, with no underneath access to bolts.
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
2/18/2017 1:39:32 AM • Porcher Home • Answered on Feb 18, 2017
How to I tighten a Porcher soft close toilet seat, one side is totally loose.
You may need a new fastener now
2/18/2017 1:39:10 AM • Porcher Home • Answered on Feb 18, 2017
Porcher 40050 Classic Elongated Toilet Bowl Only, White Logo
Popular Tags
2 questions posted
Top Porcher Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Porcher Home Expert? Answer questions, earn points and help others
View Most Popular
Porcher Home
  • Porcher Home
Most Popular Question
not flush completely works 2 out 3
  • Home
