20 Most Recent
Michele Coquette 71-800-CL-301-72 Wrist Watch Questions & Answers
Want to use larger second
This watch is a chronograph. The true second hand is the one you mentioned that is currently running (what is called the subdial hand).
To use the chronograph hand,
1) Press the button at the 2:00 location to start timing.
2) Press the button at the 2:00 location to stop timing.
3) Press the button at the 4:00 position to reset the chronograph hand(s) to zero.
To reset the chronograph hands to zero, set the crown to either click position one (usually date setting) or two (usually time setting), and use each button to test which subdial hand it will zero out.
Usually it is the first crown click position, and pressing the 2:00 or 4:00 button to zero out.
Warning: Leaving the chronograph function running will drain your watch battery much faster than using the standard second hand, as it is a complication meant for the purpose of timing an activity or other event.
If this does not zero your watch, you must either send it back to Michele, or visit your nearest Certified Master Horologist to assess the issue, as the movement may have a defect.
I need to replace a
Seals in water resistant timepieces go bad over time. This exposes the movement to moisture, dust, etc. which can damage your watch, costing expensive service or a new movement. If the watch is worn in the water often, the rule is to replace gaskets every 12 months. If it is occasionally worn in the water, they must be replaced every 18 to 24 months. The seals must be tested properly under the appropriate pressure for the rating of the watch by submerging the timepiece in a pressurized chamber. If your watchmaker is recommending this for a watch rated WR, water resistant, or 30M / 3 BAR don't bother. This should never be worn in the water. If it is for a higher rating (50M/100M+ 5BAR/10BAR+) and you wear it in the water, it may be worth the investment.
I need a new battery
Most digital watches have "standard" batteries. Invariably all batteries have a number on them.All watch battery stockists have "equivalence lists" so that irrespective of brand of battery a "generic" battery of the same dimensions - diameter and thickness ( and voltage) can be found from a "stocked:"range.e.g.a battery that is 6.8mm diam and 2.6mm thick is variously known as a SR626SW, SB-AW, 280-39, RW329 or a 606 or a D377 - dependng on the "brand" of battery - It's common name is a 377 battery - and it will fit in - and work
