20 Most Recent
Vintage 1930's Replica Cathedral Radio and Cassette Player Shelf System Questions & Answers
Cracking & popping radio
The volume control pod needs to be flushed with electronic control cleaner, unplug and remove back, attach supplied straw and give the pod two or three good blasts in the tiny hole and rotate volume back and forth rapidly to reach desired results.
Where can I get a cathedral radio with an audio in
WalMart online, Target online, Radio shack online or Sears local store.
Sears has other vintage stuff, like a turntable/stereo...
Shop Sears tonight and Save $$$ ..
Wait! I sound like a commercial!
I hope this helps!
It was working but there's no sound to my speakers from my naka michi RE - 3 vintage
If there is no sound coming from your speakers connected to the Naka Michi RE-3 vintage receiver, you can try the following troubleshooting steps:
1. Check Speaker Connections: Ensure that the speaker wires are properly connected to the appropriate speaker outputs on the Naka Michi RE-3 receiver and that they are securely attached to the corresponding terminals on the speakers. Verify that the connections are not loose or damaged.
2. Speaker A/B Selection: If your receiver has multiple speaker outputs or A/B speaker selection options, make sure the correct speakers are selected and enabled. Check the receiver's front panel or remote control for speaker selection buttons and confirm that the desired speaker configuration is chosen.
3. Volume and Mute: Ensure that the volume on the receiver is turned up to an audible level. Also, check if the receiver or remote control has a mute function enabled, and deactivate it if necessary.
4. Input Selection: Verify that the correct input source is selected on the receiver. Use the input selector buttons on the front panel or remote control to cycle through the available input options until you find the one connected to your audio source.
5. Test Different Inputs: Try connecting a different audio source (such as a different device or source) to the receiver and see if there is any sound output. This will help determine if the issue is specific to the current input or if it is a broader problem with the receiver.
6. Check Speaker Impedance: Ensure that the impedance of the speakers matches the recommended range for the Naka Michi RE-3 receiver. Using speakers with an impedance outside of the recommended range can result in low or no sound output.
7. Reset or Power Cycle: If none of the above steps resolve the issue, you can try resetting the receiver to its factory defaults or power cycling it by unplugging it from the power source for a few minutes and then plugging it back in.
If the issue persists after performing these troubleshooting steps, it may indicate a problem with the receiver's internal components or circuitry. In that case, it is recommended to contact a professional technician or Naka Michi customer support for further assistance or to schedule a repair.
