20 Most Recent
LG Wave AX380 Cellular Phone Questions & Answers
How to view pictures off
Connect the supplied USB cable from your cell phone to theUSB port on your computer.
The computer will see the cell phone as an external storage device or anexternal mass storage device, you can then open the photo folder on your cellphone and copy the photo to your computer.
If the photos are stored on a mini or micro SD memory cardthen -
An alternate method is to remove the mini or micro SD memorycard from the cell phone and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the micro or micro SD memory card and copythe photo to your computer.
My AX380 cell phone keypad was accidentally
Oh..it is to bad for you but I will try my best to help. okay.:-) so just cool and relax. You said you accidentally lock it and forgot the unlock code right? Here's one thing I want you know, it is the best one to do. Get your phone to the authorized retailer and have it unlock or take it a cellphone repair shop, they probably flash your phone and reprogram it.
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
