In my laptop(compaq presario 2100) it is not installed
PCI modem viedeo controller VGA compatible
pls help me and send this on my id [email protected]
U can do downloading all the drivers for you laptop from hp compaq website
There are two (2) different Compaq Presario 2100, 1 is an Intel based and theother is AMD based, which one do you have?
In any case if your OS is WinXP, for Intel pls try here while for an AMD. pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Hi again,
Appreciate your comment/postback.
Have you determined which version you have, Intel or AMD?
Pls confirm the OS you are needing the drivers for, Windows XP? or Windows 2000?
Were you able to at least the download page(s)? If yes, which device driver fails to download or install?
If your main concern is the Video driver, if I understand it right, the Intel and the AMD version both share the same Video driver, an ATI 8.003.3-040515a-016016C for XP.
Or are you trying to install Vista?
problem is not solved.
