Generally, most humidifiers work best between 60 -80 degrees . There is a model that is called a Low Temp model, that's designed for low temperatures in basements.
As far as your problem is concerned, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, set the Manual Control Knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
I hope this helps you troubleshoot and solve the problem. Thanks for choosing FixYa.
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dehumidifier is running but not pulling any moisture. I would check the set point and if necessary set it to a lower setting. Attempt to run your appliance on "CO" which is for continuous drain to see if any moisture is pulled out of your room. If those steps do not work you may want to reach out to the manufacture to see if they have any potential remedy for your appliance. -Matt
