My phone turns on and it says app error 523 reset, i click reset and it takes me to another white screen where it shows other error info and i see where it says device error 302 and my phone reloads then turns on only for about a minute (not long enough for me to use my desktop manager for it) what should i do to resolve this.
This error can be caused by a few different things, including faulty third party software. Have you downloaded any apps lately?
Make sure you have BlackBerry Desktop Manager installed on your computer, then unplug the battery from your BB and make sure that it is not connected to the computer. Start App Loader, then plug the USB cable into your phone. Once the phone lights up, wait to see if it starts up and if the PIN appears on your computer (in App Loader). At that point, plug in your battery. The software should load, and you can remove the third party app. If you don't think it's an app causing the problem, you can try using the repair option in the Desktop Manager. Let me know how it goes.
my phone went dead last night went i was in bed and when ive woke up this mornin ive put it on charge and the screen was white and said app error 523 reset so i reset it and it says uncaught exception:11 >11 and then went i press ok it just goes straight back to app error 523 .... and i need my phone :( how can i fix it without sending it off and paying for it?
i turn on the phone to immediately find a pop up that says uncaught exception index 6>=6 then by its self it will go to white screen that says app error 523 with a reset link beneath it
Hi, error 523 reset means a "System process died" You'll need to reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider.
2.
Delete or rename the vendor.xml file, here: C:\Program Files\Common
Files\Research In Motion\AppLoader (you're windows file options needs
to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the phone
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset: 523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
