After reading your post, it made perfect sense. In your situation, you don't want to use water to clear the PVC pipe(s), you should use compressed air. Which is what most HVAC technicians use. If you know someone that has a portable air compressor, that would definitely do the trick. You would do all this from the outside, rather than the inside.
I hope this helped you and thanks for choosing FixYa.
See if you can blow itout some way.. check the filter and be certian it is clean . Hope htis helps let me know Jon
Hello - Since you have previously replaced the bottom gasket and issue continues I suggest contacting a professional to move forward accurately. The leak could possibly be coming from the drain motor/pump or a loose hose connection located underneath.
