My lawnmower keeps on cutting out on me, it starts first time, and i have cleaned the air filter, and also changed the fuel.can anyone please help fix this problem?.
cheers..
ps its sometimes sluggish and splutters..
thanks again.
Try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Primer button sticks in on lawn mower mats rong
