Take vehicle to Autozone or Advane Auto and have the charging system checked for free. Batteries have 2 capacities. CA, cranking amps, warm weather and CCA, cold cranking amps, cold weather. Suspect new battery required.
I had the same problem. It was a solder connection in the charger socket. I tried to fix it but made it worse. I ended up having to switch the battery with a charged one from another GameBoy. That's how I was able to keep using it.
maybe you have to go to an electronic technician to fix your problem.they have the expertise in opening the gameboy and repair the broken charging port.
you can normally buy a portable charger , it sounds like the pins in the charger have gone ,so it may be a case of buying a new charger these can be picked up on the net quite cheaply
or you could try getting a needle and bending the pins back into the shape they are meant to be , to get an idea look at your other charger
Sounds like the cells inside of the battery are weak and can't hold the charge. If possible, try a known good working battery and then charge it up. If the charge holds and you can run the battery off of it for a while then you know the original battery is bad.
If you try a known good battery and the charge still doesn't hold then it could be the main board inside of the GBA is bad and you would need to get another system unless the one you have happens to still be under warranty.
You can also try a know good ac adapter at that point as well to make sure your adapter isnt flaky but if you can turn on your gba with just the adapter hooked up then more then likely the adapter is good.
