If it's an aftermarket stereo, it can be removed without taking the dash apart. It depends on how it was installed. Remove the thin plastic collar from around the radio, it may be easier to remove it with the faceplate detached. Look on the sides for thin metal tabs you can press then in and slide the radio out carefully with a flat screw driver.
Some installers will screw the radio into a dash assembly and the radio will not come out until you remove the dash. Usually cars that have a black plastic pocket either directly above or below the radio are screwed in and don't come out as easy.
If you remove the faceplate and collar, and see a thin metal cage around the radio it should slide out nice and easy with a flat screw driver or the "keys" that come with the radio when purchased new. These "keys" are just long skinny flat pieces of metal and are real cheap.
