Sony Cyber-shot DSC-T70 Digital Camera Logo
Posted on Jul 15, 2011
I have a SONY CYBER SHOT DSC T-70 camera. Recently i took foto in the fire works mode. Aftr that my camera doesnt flash in AUTO mode. flash could be on only if I put MACRO ON. In Auto mode the focusing s delayed and it takes time for focusing. How could these probs be fixes. Kindly help.
3helpful
I bough new sony cyber shot DSC Tx 10 camera but could not found the forced flash option. there is only automatic flash and no flash. How can I found forced flash??
In Intelligent Auto mode that's true, you only have Auto or Off. If you want more options you should switch to Program mode. There you can select Auto, On, Slow sync, and Off.
2answers
Problem with the Sony Cyber-shot DSC-S730 Digital Camera Model DSC-S730 Camera flash is not working
You must verify how you set the flash: auto, on or off. Set it "on" and try it. If it not work so, it's out of service. In "auto" mode it's possible to not work sometimes because light sensor.
2helpful
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
How do i turn on the flash on the sony cyber-shot dsc t77
1. Touch the Flash (Auto) icon.
2. Select the desire option.
a. Flash Auto - auto flash when needed.
b. Flash ON - Flash always ON.
You can also refer the page # 12 and 23 of 108 in Instruction Manual of the Camera for detail information to turn on the Flash.
To download Instruction Manual check the link given below:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT77
NOTE: You can not use the Flash when the Camera is set to Burst or Multi Burst mode. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection. You can not use the Flash when mode dial is set to Movie also.
Good Luck!!!!!!!!!!!!!!!!!!!
3helpful
2answers
My flash on my sony cybershot will not turn on. the button doesnt want to work it just beeps, but everything else works fine. Can I fix this?
Set camera on auto (green mark) and turn on flash by pressing flash sign button.
Or initialize camera by going into menu.
N auto mode of shooting flash setting cant be changed in sony cyber shot model no dsc w-170
as long as you have a menu button on your camera you should be able to control these functions.turn the camera on in auto or manual. hit menu soon as the camera comes on,now you should be allowed to make any chages you choose.hope this helped.good luck
Apr 14, 2009 • Cameras
1helpful
Flash shows a triangle with an exclamation pnt "can not be chngd
the flash can not be forced on on some shooting modes, just try other modes(auto.etc)
2answers
Sony cyber-shot dsc-p31 camera
Connect your camera with PC through USB link and press Camera Menu, you will see PicBridge option there, select / enable it.
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
