You may download the webcam driver from the below link and then try installing it:
http://www.dell.com/support/Article/us/en/19/SLN265814/EN
Installation guide:
Hope this helps..
SOURCE: web cam does not work
People will give you many solutions like Re-installing your web-cam driver or repair it using its CD.
But I recommend you to RESTORE your system to factory settings by using Dell's Restore Wizard.
It will eliminate all such problems from your laptop.
Have a good day.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
SOURCE: driver for webcam
You can go to the device manager and try updating the driver or reinstalling it.
Regards
SOURCE: Web cam is not working
Try using the Webcam Manager. If you are not able to fix the problem using the Webcam Manager that already installed in your Laptop, you need to uninstall it and reinstall again. To do so, try the following.
To install the correct Webcam software, you need to first update the drivers. Go to Control Panel, select “Devise Manager”, choose “Imaging Devices”, double click “Integrated Webcam”, select the “Driver” tab on the top and click on “Update Driver” option. Once you double click on this option, it runs and bring all that devices installed in your laptop. You can see the message “Application already installed in your computer”. In the bottom, you can find a message as “For Reinstalling Dell Webcam Central Software”. Click on this option to reinstall that, you will be required to reboot again. After this, you can find the option “Dell Webcam Central” in your “Start” button. Click this option and wait, it will bring the icon in the right hand side of the system tray screen. That’s it, you can double click on the icon and open it.
Hope this helps.
SOURCE: Dell latitude D 820 i can see Web cam installed
The Dell Latitude D820 never shipped with an integrated webcam
it shows no device found when i open it......
