Computers & Internet Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get my WPA if i lost my manual for the RCA DCM425
Anonymous
Level 3:
  • Computers & ... Master 32,281 Answers
  • Posted on Jul 06, 2011
Anonymous
Level 3:
Answers
32281
Questions
Helped
7913634
Points
102259
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Rca dcm425 modem pc link light
I would suggest that you go through this guide, it will explain you every step which you need to make to get your modem and internet connection back on track:
The ultimate Link Troubleshoot guide: Problems. solutions, PDF manuals
I need to connect my router to my pc. what is my security key for my RCA router?
not sure really, but you may be able to further investigating here
www.cablemodems.com/downloads/specsheets/RCA DCM425 Digital Cable Modem.pdf
The PC link keeps turning in and off
It could be Mediacom having problems if not unplug your rca dcm425 for 30 secs and plug it back in im sure you hear people say that alot but it works and if you have a router unplug it first plug it back in and then the rca.
I need to change the channel settings on my RCA DCM425 cable modem. The problem is my company set up the router and wireless along with an ASA and I do not have any of the original information. How do I...
Cable Modem Troubleshooting RCA DCM425
or
You can change the radio channel on your AirPort Extreme using the AirPort Utility, as follows:
  • Run the AirPort Utility.
  • Select the AirPort Extreme, and then, select Edit.
  • Select the Wireless tab.
  • Select Wireless Options.
  • By default, the channels for both the 2.4 & 5 GHz radios are set to "Automatic." You would first change this to "Manual," and then, select the desired channel.
2helpful
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
2helpful
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
RCA DCM425. What coaxial cable do I use? The RG6
Contact your cable provider, you most likely have a signal issue related to poorly seated fittings, outdated or wrong bandwidth splitters, or low signal from outside feed. Quadshield rg6 is the best indoor residential application though. -Comcast tech
1helpful
3answers
I NEED A DRIVER!
Took a while but i think i got the usb driver for you :-) http://helpdesk.powergate.ca/index.php?id=19 Hope it helps mate.. John
Grand Canyon Tech
Grand Canyon Tech
