I would suggest that you go through this guide, it will explain you every step which you need to make to get your modem and internet connection back on track:
The ultimate Link Troubleshoot guide: Problems. solutions, PDF manuals
SOURCE: RCA DCM425 modem ethernet connection won't work
In short, you have to either
Details below.
The modem is communicating with the servers at your ISP (Internet Service Provider) to give your computers an IP address. The ISP may have your modem set up to be issued only one IP address. Thus using both USB and Ethernet could be restricted by your ISP.
The IP address is most likely a dynamic IP that expires after a few days or weeks, unless you bought a business account that has a static IP (which is used for hosting permanent websites).
When a computer is not communicating with a Cable Modem or you shift between the connections on the modem, it may be necessary to re-establish configurations. The following can be steps to reset all components to re-establish configurations:
These steps are required when adjustments occur especially when shifting between connections on the back of the modem.
SOURCE: rca dcm425
Try this site - they have RCA425 USB drivers posted
http://helpdesk.powergate.ca/index.php?id=19
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
SOURCE: how to secure my wireless connection for a DCM425
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
SOURCE: i lost the disk for the RCA DCM425 digital cable
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
