the one side of the door switch is bad,one side controls the light when the door is open,the other side of this switch makes the unit run when the door is closed,replace the switch,or if you dont care about the door light,reverse the 2 larger connections and it will work again,but no light with door open then
Gas or Electric? If Gas it could be the gas valve isn't opening, this keeps the burner from lighting. If electric your heating element is most likely burned out.
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
