I think the sound your describing comes from the ventilation system, if you push the button on your ventilation system that controls the air recycling it should reproduce the sound that you are describing.Apparently it is a plastic gear that switches between outside air and recycling and this gear has become damaged and lost some of its teeth.
You have to dismantle your glove box to be able to get to the mechanism to replace it. I have the same problem with my 2004
9-3 and as this fault does not affect the running of the car and the ventilation system is still fully functional i have decided to leave it as is. Hope this is of some help
SOURCE: I have a 2006 saab 93 1.9 tid vector sport,79 000k
You would change t/belt at 5 years or 100,000 miles.
SOURCE: is the blower motor resistor on a dodge caravan
the one on my 96 dodge truck it was under the hood mounted to the firewall hope this helps
SOURCE: how to bypass the turbo on my saab 93 2.2 tid
No you can't.Internal damage will be done to the engine.Sorry to tell you this.
SOURCE: 2001 BMW 325i floor on front passenger side wet when it rains
You have a leaking windshield seal at the bottom of the windsheild rain gutter.
