SOURCE: Hisense LCD TL 3220 tv no HDMI
If your telly has no HDMI then I assume it mus have DVI instead. You can buy a DVI to HDMI adaptor from most good electrical stockists but the only problem is the financial one for the extra cost for the leads :-) Hope this helps.
SOURCE: We have a Hisense flat
This is caused by a bad signal coming from the the buttons board to the processor on the mainboard. This in turn can be caused by either :
1 - a bad connection to the data cable that joins them - you will have to open the tv and reseat the cables, plug the firmly, or
2 - the power source delivers a lower than needed voltage to the controller of the tv - you will need to test it: take off the back cover , take it out (the power cable plugs into it) and replace the capacitors as explained here
http://www.youtube.com/watch?v=on_2CP52cW4
If the problem returns after that you will have to inspect also the mainboard, on which the processor is situated.
