SOURCE: kef subwoofer kht 2005:2
check for the connection og the main wire is cut.. or check the supply..
SOURCE: KEF KHT 2005.2 SUBWOOFER
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
SOURCE: im having trouble with connections from kef psw
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
SOURCE: my kef psw 2150 sub
is probably faulty capacitors
you should check out this link: http://lug.demon.co.uk/kefrepair/?cat=1
