JBL PSW-D110 Speaker Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a PSW-D112 that has little use, i just hooked it up 2 days ago and was working great and I shut it off by the switch on the back of the unit now today I went to turn it on and it made a buzzing noise im using rca's the noise goes away if the rca's are disconnected but soon as I plug them back in it starts I've check all my connections and everything is in order we had a really bad rain lastnight could it be static elec. or mositure in the air messing with the connections of the rca's i dont know what it is im grasping at straws its never done this before and Im hosting a party in 3 days any help would be appreciated thankyou James
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Aug 03, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767808
Points
24828
What happens if you disconnect only the source end of the RCA's? Atmospheric noise can enter through the cables if their shields are grounded well.
Google: "speakers buzzing"
1helpful
Recently acquired a PSW-D112 Sub in good shape and also still have a PSW-D110 sub that has not really ever been used. I have been reading all the posts about these models amplifiers crapping out because of...
Or you could prepare for the worst but live in the moment and wait til it dies. You have time on your side. Plus, you could always use it as a passive sub if you have a separate amplifier. I did that with a Klipsch KSW-12 when my second copy blew its amp.
It will not power on
henrylshelt,
Your sub should turn on into standby mode when plugged into AC power without being attached to the receiver. If it does not follow the list below. If it does, the sub needs a signal from your receiver via either by line-level (RCA) or the speaker wires to turn on out of standby. Ensure that the cable or wires going to your sub is in fact sending a signal while the receiver is on. To Test, (speaker wires) hook up a different known working speaker; (line-level) Some receivers have a menu option to turn the LFE output on and off, ensure that it is on and producing a signal.
Diagnose the problem:
1) Remove all wiring to/from the unit except for the AC plug (use a different known working AC outlet), will it turn on? If so the other outlet is not working.
2) Remove the woofer, does the amp have a fuse that need to be changed? Change the fuse. If it blows again after replacing and turning back on, the speaker is blown; go to #4.
3) Unplug the woofer from the amp, does it turn on? If so, go to #4.
4) The sub need to be serviced. http://www.jbl.com/EN-US/Support/Pages/SupportOverView.aspx
-Hope this helps, Chris.
I have moved from place to place...and all the sudden I can't get my jbl psw-d112 woofer to work....i took it apart and think maybe the blue and black wire came off the actually woofer...i need to know...
Are you not sure the wires came off? If they're off, reconnect them and get back to us. Absolute polarity doesn't matter. You can always reverse the phasing with the external Phase control.
When you say you replaced the fuse, was that a wild guess or was the fuse really blown?
3helpful
2answers
When my jbl psw-d112 is on it will run just fine for a few min then it will sound like the speaker is blown. the green power light that is next to the vol level knob starts to turn red. What does this...
That model is known to have issues with the amps.Your problem is caused by a couple of components on the board shorting out.If you pull the amp out you will find on the large board behind the speaker terminal a couple of burned components.
The easiest fix is to buy a Bash 300w amp from Parts Express and replace the original amp.The Bash amp fits pretty well except that it is about an inch shorter.You can fill the hole with some mdf and have a sub that actually performs better than the original and with less heat build up as it is digital.Hope this helps,it's not complicated really.
JBL subwoofer PSW-D115
Hi Im a Certified Repair technician, I seen few problems with this unit, there is a amplifier module inside this unit, is really hard to find since JBL discontinued this almost immediately.
Sorry no really worth to bother........
Power not working
If it is fused check to see if the fuse is blown... Start with power and work you way down from there.
Power to the sub.
Signal to the sub
Cabling to sub
Check the speaker itself to see if it is good.
john
2answers
JBL PSW-D112 Speaker fuse blow immediately after replaced
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
JBL PSW D112 Distorted Sound
your memory is low on resources need to increase memory.everything on ur pc uses mem.audio and video devices use an aweful lot.if you have open another program not only will ur audio be distorted but ur other program will be running slow.
correct? need to add more ram.
SYLVAN.
THE FILTERS /FILTRES ON YOUR SPEAKERS ARE TORN OR DAMAGED. IF YOU STILL HAVE WARRENTY ON THEY FROM JBL YOU CAN RETURN THEM FOR NEW ONES, PROVIDING THAT IS COVERED. IF NOT. I PERSONALLY RECOMMEND YOU BUY YOU SOME NEW ONES. REPAIRING WOULD BE OK, BUT IT WILL HAPPEN AGAIN VERY QUICKLY.
Thank you. Let me know what your decissions are
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
