Roper RGX4634KQ Gas Dryer Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
8 month old roper gas dryer. The dryer makes a buzzing sound when on any heat cycle. Like the buzzer sounds when the drying cycle is done. but this dryer does not have a timer. it will stop buzzing on the cool down settings.
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on Jun 30, 2011
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707736
Points
7484
Take it back its still under warranty dont pay to fix it
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
1helpful
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
2answers
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Buzzing sound
USUALLY WHEN MOISTER SENSOR DETECTS CLOTHES ARE DRIED THE BUZZER GOES OFF TO LET U KNOW SO MAY HABE BAD MOISTER SENSOR, UNLESS THE CLOTHES ARE DRYED WHEN IT GOES OFF
I have an electric dryer, Estate by Whirlpool, It runs perfectly fine on no heat, it also works well on the cool down cycle of a regular cycle. However, if you try to use it on anything else, when you push...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 16, 2011 • Dryers
Buzzing every 30 seconds
you can remove the buzzer its a small black round peice with a small hole in the middle on the main ic .p.c.b bord but if its buzzing there might be a problem if the unit is working fine then just snap the buzzer off the curcuit bord
I want to disconnect the buzzer sound on my dryer
First of all if you can remove the back of the console to expose the timer and switches, there is usually a small block with 2 wires to it, and it has no knob connected, this is usually the alarm buzzer, remove 1 wire and tape it off,then try the dryer if no alarm wala.
We have a Maytag dryer that is 7 years old. It runs on propane. Recently it started getting louder during the drying cycle and it keeps getting louder. It sounds almost like a buzzing (NOT like the...
Never saw a response to my clarification request, so I hope you have resolved you service question. Without further info, it's hard to give good advice, but you might look at the blower wheel to see if it is spinning loosly on the motor shaft. That will make noise, and usually continues for a few seconds after dryer shuts off.
Sep 04, 2008 • Dryers
15helpful
2answers
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
