Jasco makes the camera for the GE name. The drivers for the GE EasyCam (and other GE web cams) are available for Windows 95, 98 and XP from http://www.jascoproducts.com/support/software-downloads.asp#pccams . Check your model number, the EasyCam listed is 98063. The direct link to the driver is http://www.jascoproducts.com/support/download-files/98063.zip . Right click on the file after downloading and select Extract All. Then install the driver by pointing the Windows wizard to the appropriate folder where the files were extracted to. The instructions are available in the right hand column from the first link.
If it is a new cam, and you are running a newer version of Windows, like 7 or 8, the driver should be in the OS. But when the cam is somewhat older, and GE did not write a certified driver for the newer versions of Windows, you won't be able to install a working driver for that cam.
The software should be available on the GE website in the US. (older drivers to)
Okay you can try and go on the internet and see if there is a driver download for vista for your cam.
This usually works
If not I would probably suggest an updated camera since vista was made for newer versions.Just make sre your new cam supports vista
http://www.jascoproducts.com/support/software-downloads.asp copy and paste the above line into address bar press enter will take you to site with driver for your cam listed sorry its only for xp not vista cannot find driver for vista
i can not get my easy cam to work with my new computer and ican find a way to get it to work on vista
