Today the heat system on my toyota avalon 98 failed. There are lights on the dash which show if the air is going to come in fresh or circulate.That light did not light. The blower did not work. And the outside temp guage which always works upon start up did not work.
I think this may be a fuse problem, but I have no clue which fuse is the right one to check. There is no chart available to me.
Anyone know what to do?
Thanks.
Ray
Hey Toyota Ed.
My problem solved itself. After driving the car a few times, with several re-starts of the engine, suddenly everything worked. This does not lend to a confident driver,because at anytime it can happen again, but for now I can't fix what isn't broken. Thanks for the offer of help,anyway.
Ray
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
These will help.
Thanks.
Do you have "automatic A/C"?
If so, the problem that you are describing may require the replacement of the A/C amplifier. But, further diagnosis would be in order before I went out & bought one; they are quite expensive.
