SOURCE: problem in Sony DSC T20
sounds like camera has problem with one of motors in the lens assembly .The camera has a motor for zoom functions, motor for focus , motor for iris inside lens and a possible motor for the lens cover on front cabinet.One of these motors could be binding or a switch on lens area could not be working..
SOURCE: My Sony DSC-T2 was dropped on tile floor and now
Since, the Camera is shaking, it confirms an internal hardware damage.
In this case, it's required to get the Camera serviced.
SOURCE: Vibrating Camera
This is a known issue with the DSC-T20 Cameras.
Check this link for more information and get it serviced to resolve the issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT20&news_id=269
NOTE: (Please confirm the model # of the Camera whether it is DSC-T20 or DSC-T2. )
Good Luck!!!!!!!!!!
SOURCE: My DSC-T300 Sony Digital Camera is keep vibrating
I have the same troubel here! Anybody can help us?
SOURCE: my sony digital camera was vibrating what is the
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
