SOURCE: Set probe temperature
If i remember correctly i believe this is actually a wiring issue. you would need to turn the power off open the control panel. and look for a control board with the probe connection on it. there should be a tech sheet in the compartment to help you identify it however if it is the problem they would be purple wires on the connector that need to be reversed.
SOURCE: my oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
SOURCE: my oven is hotter than it shows
If you remove the dial you should find an adjustment behind the dial to match it to the temperature.
SOURCE: Zanussi ZBQ 965(X) Built-in Oven
oven no longer works no lights on clock , hob works which is on same feed ?
SOURCE: the bottom oven on my zanussi zuq 875 has stopped
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this
problem the sensor needs replacement. If you want to be sure before replacing
the sensor then you can test it with a voltmeter for around 1100ohms....if it
reads more than this then it needs replacement however, if the reading is
around or less then 1100ohms then it is the control board that needs replacement.
Please get back to me if you have any other questions.
Kevin
