If your memory card is showing memory card corrupted both on the phone and your computer, then it means there is a problem with the memory card. Most likely the memory card would have been corrupted by a virus.
What You will have to do is to try to run an anti virus scan on the memory card. To do so, when You connect the memory card to the phone, You will have to right click on the memory card, then select scan using the anti virus of Your choice. Then it will scan the memory card and wipe out all corrupted files and viruses.
After doing so You can format the memory card before using it again.
If it does not work, then it means the memory card is damaged beyond repairs.
Hope this helped.
Thank You for using FixYa.
