You can try the following codes for your APEX tv:
0214 0216 0215 0401 0156
Here's how to program your remote:
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired device button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit code
Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press ON•OFF. If the device turns off, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
SOURCE: code for apex tv through philips universal remote
I need help too wiht the same remote and TV ( APex)
SOURCE: need apex tv code
the standard codes for apex are: 0023, 0223, 0123, 1814, 0741 .try each one of these until you find what works with your tv.
comment if you need any further help or if these do not work.
436
Four digit codes are:
0214 0216 0215 1132 0401
OK.
