no car told at all year yes. sad face and sorry no fuse to tell for just that 1 reason, and no engine told as fuse boxes vary buy ENGINES.
sorry 100,000 models of cars and all that,
now the generic answer and posted here vast times , 1 more.
first off what does UNIT mean to you, me zero.
AC dead , NO COLD air summer, are you in the FLORIDA keys?
there are to macro causes,
1: the R134 loop is dead. or weak.
2; or air distribution system (cab blower etc) is failing. or weak.
and we do this in that order, LOOP first. and using gauges for
low side and high side to be in spec, per the manual.
the dead compressor has these causes.
1: R134a leaked out as
ALL DO and the high low Freon switch is tripped open, saving destruction of the compressor total, and worse.
2; the blower is dead in cab, if dead (no 12vdc to ) the AC is disabled so the core can not ICE up and brick out (more bad that)
3: the BCM runs this system, with aid of the controller AC.
4: fuses blown to AC clutch
5: relays blown to AC clutch and its fuse.
6: 12vdc makes it to clutch is a bad clutch or omg seized compressor.
all it takes is a volt meter and service manual on the car.
and even scan the PCm/BCM and it tells you OMG blown fuse X
the car has glove box guide there, turn to chapter fuses. read that.
or if lost that, buy one in usa the guides are free, PDF. and easy to find googled in seconds,
the service manual is here, (I too must pay for top manuals)
https://eautorepair.net/Marketing/Default.asp
the clutch also goes OFFLINE (on purpose)
if the BCM controller sees Evap core IS up (a sensor)
or if outside air is too cold so try defrost mode.
the BCM also cuts AC off line if engine or transmission shows overheating NOW. saving engine for destruction (warped heads no fun)
some cars see ENGINE in PCM limphome mode ,cut AC dead.
those are all called now, today, permissive's.
seen same thing when throttle by wire fails.(LIMP) car is a slug.
so if CEL lamp is on the
PCM must be scanned first.
good luck , tell more get more
no car told at all so........a hard nut case here.(nut to crack)
