2000 Oldsmobile Intrigue Logo
Posted on Aug 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Crank position sensor location
I have a 2000 olds intrigue and i need to replace the crank position sensor and i cannot locate it can anyone help me thanks
  • 1 more comment
  • Anonymous Mar 13, 2014
    Where is the crank position sensor located
  • Anonymous Mar 16, 2014
    i need a picture of the location of crank position sensor on a 04 optima 2.7
  • Anonymous Apr 01, 2014
    CAR CRANK BUT WILL NOT START
Jonathan Dawson
Level 2:
  • Expert 50 Answers
  • Posted on Aug 18, 2008
Jonathan Dawson
Expert
Level 2:
Answers
50
Questions
0
Helped
33166
Points
201
You will need to remove the starter to gain acess to the ckp sensor. once you remove the starter look on the engine block and you will see the sensor. The only problem with doing this repair yourself is that you will not be able to preform the crankshaft position variation learn procedure with out a factory scan tool. The vehicle may crank an run, but the timing advance curves will be wrong so the vehicle will probably cut off every time you remove your foot from the gas pedal. Hope this info helps!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
  • Anonymous May 14, 2013
    your reply was for the 1996 olds cutlas 3.1 v-6?
BCM LOCATION 2000 OLDS INTRIGUE
It is located under the dash left side above the parking brake ! There are four wiring connectors to it !
1helpful
I have an 2000 Oldsmobile intrigue and i need to replace the camshaft position sensor, where is it located and how hard is it to replace it?
Well if it's the 3.5 SFI engine, it's on the timing chain cover,toward the top of the engine, held in by one 10mm bolt. If you have the 3.8L it's built into the ignition module. The crank sensor is a pain in the **** on the 3.8. That's located above the oilpan, toward the rear of the car, in between the transaxle & engine,also held in by one 10mm bolt. Check out autozone's website for more info.
Where is the Crank Shaft Position Sensor located on the Oldsmobile Intrigue 2000
The crankshaft position sensor is located just above the starter on the engine block.Hope this helps.Good luck.
Where is the Crank Shaft Position Sensor located?
The crank shaft position sensor is located just above the starter on the front of the engine block.If your not sure what you can do is purchase one and then look at the connector end to see if it looks the same.Hope this helps.Good luck.
1helpful
Wer can i find the crank sensors on a 99 olds intrigue 3.5 engine
The crank sensor is located below the front exhaust manifold and above the starter. To access it, you must lift the front of the vehicle, and remove the starter. Once the starter is removed the sensor is visible. Because of the poor location and poor GM engineering these sensors fail. You have excessive heat from the exhaust and oil leaking from the valve covers that short them out. Also once the sensor is replaced, it must undergo a re-learn process. Unfortunately this process can only be performed by a GM dealer via their computer system.....if you need further assistance, feel free to post them on FYa...hopefully this helps!!
It is on the front of the motor under the manifold, you have to remove the starter first then it is right there on the block. make sure you diconect the battery befor removeing starter
12helpful
Trying to replace the crankshaft position sensor on a 2001 olds intrigue and cannot locate it. Where is it?
Hello suewagner.
The crank sensor is mounted above the starter motor on the firewall side of the engine. The sensor picks up the signal direct off of the crankshaft through a machined hole in the engine block.
I have removed them without dropping the starter but learned that in most cases it is easier to drop the starter down to access it.
Here is a diagram for you.
There you are, hope this helps you.
Take care,
KL
2answers
Where is the crankshaft position sensor located on a 2000 intrigu
Should be located around 11:00 on front of engine at crank pully.
2answers
Long crank time for 2000 olds intrigue 3.5
first thing i would do is replace your fuel filter.
with a fuel filter restriction it take longer to provide enough fuel pressure to fire.
that would be the most common but there are also may other things that could have happened but would need more information to do a process of elimination
good luck
paul
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
